doni49
Message 1 of 4 (175 Views)
Mapexport->Select C3D object -> Objects Filtered Out?
175 Views, 3 Replies
02-06-2014 10:40 AM
We're trying to develop procedures for converting our CAD data for use in GIS.
THe following post indicates that you can export C3D objects but when I try to select a feature line, I get "1 Object Selected (1 Object filtered out)" and the resulting shp file is BLANK.  What am I missing?
TIA!
http://www.cadtutor.net/forum/showthread.php?49460-Autocad-Civil-3d-dwg-to-gis
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
Neilw
Message 2 of 4 (167 Views)
Re: Mapexport->Select C3D object -> Objects Filtered Out?
02-06-2014 11:08 AM in reply to: doni49
That thread you listed is misleading. While C3D has Map, Map does not support Civil 3D objects. I think you'll have to first export to Autocad to dumb down the graphics, then export to shape from there. Be aware that arcs on your featurelines will become tesselated polylines. Not what you wanted to hear I'm sure.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Member
kenm
Message 3 of 4 (139 Views)
02-06-2014 08:58 PM in reply to: doni49
Doni49,
The key here is to export C3D objects to an *.sdf file first, and then do a bulk copy to *.shp.  See the help in Map on how to do the Bulk Copy.
or follow this link:  http://www.augi.com/library/convert-civil-3d-data-to-shp-files  it is similar to above.
Regards, K
Neilw
Message 4 of 4 (125 Views)
02-07-2014 07:27 AM in reply to: kenm
Exporting to SDF is an interesting approach. Sadly the exported linework is tessellated just as it is when exporting to ACAD. The main advantage of the SDF export could be the preserving of attribute data, but I don't know what types of data is included with different C3D objects that would be of any use in GIS scenarios.
WIN 7 64 PRO
RADEON 6450, 1 GB
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
