I am using the mapconnect command to import a geotiff file to NAD83 coordinates. After import, the image displays correctly at the correct location, however my xref manager indicates that the image file location is in my local app folder within the C drive on my computer even though I specified the target base file on our network server. I also noticed the mapconnect function converts the files to a png file.
Because the image link resides on my computer others cannot view the image when they open the drawing. I don't fully understand how the mapconnect function works, do I need to use the mapiinsert command if I want the image to be hard linked into the drawing?
Thanks in advance for your Help!
Alex E.
Solved by Murph_Map. Go to Solution.
Solved by antoniovinci. Go to Solution.
Exactly, sir, but don't forget that image won't be embedded (like OLE does, for instance).
Drawback: the _MAPIINSERT command does not transform the image Coordinate Reference System on the fly, so you'd better convert it to the destination CRS in advance (e.g. thru Mapwindow_Gis).
If the image you connect to is on your hard drive and not a network shared folder then other users will need rights to acess your hard drive. Are the other users also using Civil3D or Map3D? When you export a mapconnected project to AutoCAD DWG format it does create a .png file and places in the folder with the dwg or in your support folders.
Thanks. Others in our office do have access to Map and Civil so I will probably try both options (mapconnect project export and mapiinsert with proper coordinate settings) and see what works best. Thanks for taking the time to answer my question!
