AutoCAD Civil 3D General
mikeevans
Message 1 of 4 (128 Views)
MapExport / ExportCivi3dObjects to SDF
128 Views, 3 Replies
08-02-2013 05:28 AM
I have custom object tables added to civil3d pipework objects so that I can export custum info for BIM purposes.
When I use the ExportCivilobjectsToSdf commandI get the usual entries into the SDF object tables but the attached object table & data do not pass over.
When I run Mapexport no objects are exported?
Is there a way apart from creating a join to export this data?
Civil3d 2013 / SP1, S3d 2014 (unused)
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Murph
Message 2 of 4 (103 Views)
Re: MapExport / ExportCivi3dObjects to SDF
08-02-2013 04:25 PM in reply to: mikeevans
Nope, Civilexort doesn't see the Map OD tables and the mapexport can't read the C3D objects.
Murph
Supportting the troops daily.
neilyj
Message 3 of 4 (90 Views)
08-03-2013 12:40 AM in reply to: mikeevans
the software is incompatible with itself...:-)
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
mikeevans
Message 4 of 4 (61 Views)
08-05-2013 02:44 AM in reply to: mikeevans
Well, I am not bearing a grudge due to incompatibility.
I have moved on and created a code to extract all the pipe / structure information (needs a bit of tweaking), explode the objects and add the object data tables so I can pass the information correctly to Map.
The goal here is to also get this information into Revit but I think I may have bitten off a huge chunk that I can't swallow there.
Thanks.
Mike Evans
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
