I have custom object tables added to civil3d pipework objects so that I can export custum info for BIM purposes.
When I use the ExportCivilobjectsToSdf commandI get the usual entries into the SDF object tables but the attached object table & data do not pass over.
When I run Mapexport no objects are exported?
Is there a way apart from creating a join to export this data?
Civil3d 2013 / SP1, S3d 2014 (unused)
@mikeevans wrote:I have custom object tables added to civil3d pipework objects so that I can export custum info for BIM purposes.
Nope, Civilexort doesn't see the Map OD tables and the mapexport can't read the C3D objects.
Well, I am not bearing a grudge due to incompatibility.
I have moved on and created a code to extract all the pipe / structure information (needs a bit of tweaking), explode the objects and add the object data tables so I can pass the information correctly to Map.
The goal here is to also get this information into Revit but I think I may have bitten off a huge chunk that I can't swallow there.
Thanks.
