I set up a queery to bring in lot numbers from object data in another file (see untitled.png) but I can't seem to get the correct data. Even though I query Lot the query always brings in the Mun value (see untitled2.png).
Anyone else having issues with queries? Can anyone see any issue with the way I set up the query?
John Mayo
Solved by Murph_Map. Go to Solution.
Solved by rkmcswain. Go to Solution.
Messed around with the profile.aws and got it fixed. all of the bold values were ones I changed.
<Tool CLSID="{6D32A2D9-832E-11D2-A83C-0060B0872C0B}">
<CAdUiDockControlBar Orientation="-1" AllowDocking="1">
<FloatInfo Left="0" Top="0" Width="494" Height="337"/><DockInfo Left="0" Top="0" Width="0" Height="1025" MRUDockID="59421"/></CAdUiDockControlBar>
<CAdUiPaletteSet ActivePaletteIndex="0" TitleBarLocation="1" AutoRollup="0" Name="Properties" Style="4142" Opacity="100" RolloverOpacity="100" Visible="1"/>
John Mayo
Really? ?
It's not slow for me. I can generate labels (and convert them to AutoCAD text if needed) in W A Y less time that I can using Map Import.
Maybe I'm missing something..?
Me too
Your Name
Your Name
John, I think I see what the problem is/was in your query. You have Object Class and Object Data selected in the first png. Looks like that is a bug in C3D 2014. It should unselect the object class if you select object data. At least that's how it works in Map 2015.
Any how here is a screen cast of the process that I used.
Extracting the text is a faster operation. No argument there. It's the pans, zooms and trying to draft over the data that is slow.
John Mayo
Yes drawing over FDO can be trying. I'd suggest a work flow to bring it in with FDO >> save to dwg and turn off the FDO layers.
Your Name
Your Name
It looks all right to me John. What do you have set under Alter Properties? I tend to use the FDO method if I have the original SHP or database available.
Allen
I hate when the site hasn't refreshed and I end up replying to a post that has had 26 replies in the mean time.
Allen Jessup
CAD Manager - Designer
