I set up a queery to bring in lot numbers from object data in another file (see untitled.png) but I can't seem to get the correct data. Even though I query Lot the query always brings in the Mun value (see untitled2.png).
Anyone else having issues with queries? Can anyone see any issue with the way I set up the query?
John Mayo
Solved by Murph_Map. Go to Solution.
Solved by rkmcswain. Go to Solution.
This does not address your question directly, but if you do not get an answer soon, have you considered bringing in the data using FDO, then extracting the autocad annotation from that? It looks like a long process, but once I got it down I can do it quickly now.
I concur with RK and there you can validate the data table contents of the field you seek
Thank you all for chiming in. I appreciate the input.
Randy and Joe, I will give that method a shot. Might not have time today but I'm sure it will work fine. I just need some text labels.
Murph, 23MB zip file with the esri data or 36 MB dwg... They won't post here. I got the data here.
https://njgin.state.nj.us/NJ_NJGINExplorer/IW.jsp?DLayer=NJ 2012 Orthophotography MG3 AutoCAD
Quick intructions to get the data from this server.
Zoom to the middle of NJ. Mercer County is on the western state border. Note the drop down list for the datasets to download. I am using the, 'Counties by County/Muni' dataset. Select this dataset. Use the Select by Point tool and click in Mercer County. Check the radio button for Mercer in the right Selection Panel. Down on the lower right click the Add Items to Cart and then click the # items in your cart for download link to get the data.
Neil, I have not used a query in years & I am trying to get the proccess back so yeah there may be some issues with the way I set it up. 😮
I will review and try again. The labels are being generated with the query but they are not showing the info I queried... the lot num. If I query lot num or block num I still get the mun number.
Thanks again everyone. I will post back when I return to the task.
John Mayo
Murph,
I had to apply the 'providers' fix before I got the shp files to work.
John Mayo
Randy, Joe,
Tried the FDOhhhSoSlow method, got most of the correct labels but not all lots. Need to check object props but props dialog will not open with the contextual ribbon the map theme is displaying and crashed trying to close it...
John Mayo
Repairing...
</sarcasm>
It's also good to know the mothership and the stockholding pilots have them all working on 360 and infraworks!!
John Mayo
Editing the profile.aws as noted here does nothing.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Properties-Palette-Missing/td-p/3502120
Uninstall and reinstalling now....
John Mayo
John
I know your situation is dire, but thats some funny SH%$ in your last few post.
Has anyone else tried this shp file? You are welcome to sedn it to me. If I can help I will.
Thats precious!
