I am using Civil 3D 2010, and have a problem with my Map Import when in the Map 3D workspace. I have updated my software with all the latest Service Packs (the latest was 3.1). The error message is: "AutaCAD Map Warning: Module AcMapImpExpUI.arx cannot load module AcMapImpExp.arx. The module may be missing, or another component upon which it depends may mot be configured correctly." Please help if you can.
As far as I can tell from a quick search these are the steps you should follow. Check after each step to see if it's cleared the error.
1) exit Civil 3D and restart the program.
2) Shut down the computer, reboot and restart Civil 3D.
3) Repair the program.
4) Repair the program again.
I did not see any instances where the error persisted after a second repair.
Allen
Allen Jessup
CAD Manager - Designer
