Does anyone know what Map 3d features are not included with C3D 2014?
Civil 3d help provides instructions but with this disclaimer,
“Please note that not all of the AutoCAD Map 3D functionality is included in AutoCAD Civil 3D."
Specifically looking at
Exporting Maps to AutoCAD
I need to maintain blocks
If you're talking about exporting a drawing with an FDO connection to a static DWG. I know that it can be done. I don't ever remember dealing with blocks. Do you have a mixed drawing with an FDO connection and individual blocks? You might try WBlocking the blocks to a new drawing then saving the FDO data to AutoCAD.
Allen Jessup
Allen Jessup
CAD Manager - Designer
Thanks for your reply.
This is what I need to do: http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesMAPC3D/GUID-C7148DC1-4888-436A-9D4C-039C...
See note at bottom of web page. I believe I need the wizard to export styled points (using blocks) to be included in the
drawing as blocks. Using "Save Current Map to AutoCAD" or "MapToACAD".
The only prompt given is "Select a method for converting line style thickness [Lineweight/Polylinewidth]"
The drawing does export but blocks are all exploded.
It looks like it would be possible using THIS method. As I said. I haven't done it with blocks myself. From what I read. It looks like clicking on Tools in the Task Pane gives you different options than MapToACAD.
Allen
Allen Jessup
Civil 3D. OK the help file is WRONG. It's Maps not Tools. They moved it but didn't update help. However I don't get a Wizard. So I don't know if this will be any better. You might want to start a Support Request on this.
Allen
Allen Jessup
I know I've tried that too. Just wonder if it works in MAP but not MAP in Civil 3d.
Anyone using just MAP getting this to work?
Hi Murph,
Have you ever put together a list of the Map commands that are disabled or modified by Civil 3D. I have someone in Supports ear about this subject at the moment.
Allen
Allen Jessup
Allen,
No I haven't. I'm not using C3D that much to do anything other than test issues I heard about. I do remember that at the summit in SF in May that Jeff Sanders didn't think there were any other than the map3d commaands that Civ3D had better commands for. I did email Jessica (from the round table) an example that I found with the display manager and map tools/map queries. Never heard back on it.
Allen Jessup
Thanks Murph. Maybe I'll try to put something together.
Allen
Allen Jessup
Allen
I heard ya the first time. 🙂
It's kinda of slow this time of the year at the shop so I may take the laptop in and see what I can find as well.
I'll have to send that one to my family to be used at the inevitable competency hearing.
This is what I have so far. I'm sure I'll find a lot more with a little experimentation. Basically any Map command that creates or inquires about cogo will be disabled or modified.
MAP COMMANDS IN CIVIL 3D
Do Not Work
MAPCGLIST
MAPCGCDIST
MAPCGSETUP
MAPCGAZBASE
Do Not Work as would in Map 3D
MAPTOACAD No export Wizard in Civil 3D
Allen
Allen Jessup
in addition: all TB* commands (previously TB for TopoBase, now included in base Map3D, but not in C3D).
- alfred -
Hi Alfred,
You're correct. Topobase isn't included in Civil 3D. What I'm looking for however are commands that appear in the Map Help portion of the help files shipped with Civil 3D. These also appear in the Autocomplete function. So if you start typing them. They will appear in the Autocomplete list. But when selected yield Unknown Command.
Allen
Allen Jessup
