Civil 3D Forum
Manhole Labels in 2013 UKIE Template
2 REPLIES 2
chrisr101
370 Views, 2 Replies
Has anyone had a problem labelling manholes when using the 2013 ukie template? - pipe labels show up but nothing else.
If I open the label style composer it looks fine in preview, visibility is set to true and its on the same layer as the pipe labels so should display OK.  It seems to be a template setting though because if I open the metric or imperial templates and draw a network the labels all work.
Any suggestions would be appreciated ... if I can find the right tick box it would be quicker than labelling with mtext.
2 REPLIES 2
troma
in reply to: chrisr101
Here's one suggestion: Try typing the command DISPLAYMANAGER and checking in here:
Lots of tick boxes to choose from.
Mark Green
Working on Civil 3D in Canada
chrisr101
I've given that one a try and it looks like all the right boxes are ticked.  I'm feeling a bit defeated by it but have thought of a workaround - data shortcut the networks, bring them into the 2012 template (the labels worked on that one), explode the labels and copy back into the original drawing.  Its not really ideal but quicker than mtext - hopefully it will all be fixed in 2014 (I tried copying the structure styles from the 2012 template into the 2013 but that didn't help either).
Rail Community
