I created my custom Sheet Set with my desired Sheet Set properties. I named it "wizengr.dst". Who knows how I can make this DST file the default so that the "Creat Sheet" wizard and "Create Section Sheet" dialog box will automatically use it to create a sheet set during sheet creation process.
Solved by DaveM. Go to Solution.
I created a folder on the server and saved my example there so everyone has access. Then i create the sheet set before i run create sheets and select from example. Then when i create the sheets i select choose existing sheet set.
I am not sure how you could choose your settings during the create sheets process.
Hope this helps.
I've been wondering the same thing recently. Do you find this helpful:
http://docs.autodesk.com/CIV3D/2013/ENU/index.html
I could do with a little more detail, but it gives me a clue, along with Dave's comment.
Mark Green
Working on Civil 3D in Canada
Thank you, Dave. That's the solution. I checked the "New sheet set" bubble instead of the "Add to existing sheet set" bubble. I was thinking the program would grab my custom sheet set template just as it does with my QNEW command for new DWG. I should have known better.
here, no?
Your Name
Your Name
Joe,
Is this setting for the example sheet set, to create a new sheet set (.dst file)?
Or is it for a template drawing file, to be used by the sheet set for creating new sheets (.dwt file)?
Mark Green
Yes. But lets clarify the Sheet Set Template File Location is the folder that can contain any number of dwt files for different sets.
two lines down in options Sets a specific dwt file for a specific type of set, 34x22 or 30x42 etc
these dwt would conatin the various elements you want to carry over to a dst file. there is no "dst" prototype they are made on the fly.
What I have done is create seed project foloder with predefined dst file in them - just copy, rename and go
Your Name
Your Name
Mark Green
Your Name
Your Name
Mark Green
I'm going to make a confession here: I have gotten very slopy with my project drawing naming (yikes) but anyway - renaming the sheet files is not an issue as far as job number goes but the data files are a bigger pain is the A$$. If you had to do that you woud have to repath all the sheet layouts for expect path vs found path
I named all my data files with generic names and leave them like that - which if the $H!T hit the fan I might have a problem but its worked for nearly 15 years without any hicups.
This is what my seed folder looks like: Design refs Xref as relative path, so when I copy and rename the root the relative path holds relative to the design folder and everyone stays together. Very useful for archiving too; etransmit to the ARCHIVE folder and done. If I had to give the data files projectnumber names I would do the same, but with a trick: xref manage can use any name for an xref, so I would maintain the generic name in the xref manager for the sheets, rename tha data files use the reference managers to repath - it would take all of 2 minutes longer to set up a jopb folder
Your Name
Your Name
Your Name
Your Name
Mark Green
Your Name
Your Name
So when we select the "New Sheet Set" checkbox in the Sheet creation process where does the Civil 3D get the default .dst template it uses to create the sheet set for the present sheets? Is it from the path in the Template folder as pointed out by Joe above?
That's my question as well, because I have set up some attributes to the .dst file, but when Civil creates the sheets by itself, it uses other default that I have no idea where it is, the other option would be to copy and paste my default .dst in every single drawing that I have for each project and ask for Civil add to existing one.
Another issue that we have here is that the AutoCAD doesn't have attributes to Sub-set, and in our case, the Sub-sets are the category of the projects, like Drainage, Architecture, Civil, Structure and so on, so there are some attributes that are different from for each category, and to fill this attributes I would have to fill one sheet by one, that's is not save time doing.
dst defaults as you say come from no where. they are simply the OOTB settings of SSM.
If you are referring to creating plan production sheets you would want to create your sheet set first and choose the option to add to existing
if you are referring to creating it is always "by example" if that option is not chosen then you get the OOTB defaults. the beauty of the dst is it is very portable.
Yes you can copy paste you preferred dst fro file to file
There is indeed a subset field under Sheet set fields CurrentSheetSetSubSet or something like that. you'll see it . I use it all the time
Your Name
Your Name
Thank you for the answer, yes I was referring to plan and production tool, at the moment we are using exaclly like that, adding to an existing dst, but we would like to be able to set custom properties to subsets, and unfortunately there is no such a thing to do it in the AutoCAD, only by Add-ins that cost $ 50, and even with that app we will be able just to copy and paste information into multiple sheets, about the field "CurrentSheetSetSubSet", it is not so usefull to us, because we need to define custom properties for each sub-sets (disciplines) and jsut gettind the name of subset is not enough to us, but any way thank you very much for your attention.
Your Name
Your Name
Your Name
Your Name
