Civil 3D Forum
Making drumlin shapes / rounded mounds in C3D
12 REPLIES 12
Message 1 of 13
1373 Views, 12 Replies
Hello all.
I am trying to model earthworks into drumlin / rounded mounds. It will be in a play area. I have made a trial using feature lines that I have used as centre and graded on the right/left sides. See image attached.
The result as shown is not the nice rounded, flowing shapes that I am looking for. How do I model this in C3D?
I have been thinking should I use alignments and assemblies however that seems hard to control. There must be an easier way...?
Any creative thoughts welcome!
Regards
Erik
12 REPLIES 12
Message 2 of 13
david.zavislan
Apply surface smoothing. The Smooth Surface command is located in the surface's Edits shortcut menu.
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 3 of 13
Sometimes you just have to draw the shape you want with contours.
Message 4 of 13
I would use AutoCad's 3D Modeling Commands to create a more organic shape.
Then convert to a surface if you need it in C3D.
tpivo
Core i7 920
Vista/C3D2011 64bit
Message 5 of 13
I was thinking along those lines but I didn't know you could convert ACAD
surfaces to C3D surfaces. How is that done?
Message 6 of 13
One way to get a pseudo mound is to create several alignments and profiles
that cross the mound in a radial fashion and generate feature lines from
them. Then add them as breaklines to a surface. The more you create the
better the results but it makes for more work to manipulate and keep
everything synchronized.
Message 7 of 13
AllenJessup
I might draw a Featureline that represents the cross section of the mound the copy/rotate it a number of times to form a mound.
Allen
Allen Jessup
CAD Manager - Designer
Message 8 of 13
Not sure of a direct way, But you
1. could make a mesh, solid or surface.
2. Export to r12 dxf
3. Import dxf into C3D
4. Create surface from breaklines
That worked on a simple model I used.
Good luck.
tpivo
Core i7 920
Vista/C3D2011 64bit
Message 9 of 13
here's the sample I used.
Message 10 of 13
Thank you all! Various good and interesting starting points here. As a landscape architect I find I am often looking for more organic and flowing shapes.
What about having a "Pamela" function with which one might enlarge and reduce organic shapes according to need, and, and....
Message 11 of 13
Are you looking for something like shown in attached?
Message 12 of 13
I played with meshes and made a cone look like this, and I am looking to add more of these next to each other and with that will be able to illustrate my intentions. If they are to be built, i will have to put the right image into the head of the operator of the machine. Again Thanks!
Message 13 of 13
Once you have the meshes as you like them you can explode them into 3D faces
and add them to a surface. Then they can be imported into their machine
controls for construction.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5135 (20100521) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Rail Community
