Hi, is there possible to make a surface from pickets i have in topography, if yes, how ? Iam adding jpg aswell. Iam just learning, so please be patient with me 🙂 Thanks
First welcome to the forum.
Second, I'm not sure what you mean by "from pickets". Based on your image, I can only guess that you want the points to define the surface.
If so, create a blank surface. Then in toolspace, expand your new surface, goto Edits>Points>Add Points OR Edits>Point Groups>Add Point Group.
Don Ireland
Engineering Design Technician
Well i did that, but i havent any surface yet and i actually dont know if i am right, but what i did. I created surface, next i went to definition and to point gruops, i selected all points and added them. But nothing happened .. Maybe my points are not right or something. I giving you to check.
The drawing includes blocks which I assume represent survey points. It would be possible to use them as part of the surface if they were inserted as the correct elevations, but these are not. Is it possible for you to get the coordinate file from the survey?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I think, i cant get that file. But i have countour lines, maybe those would help us to make proper surface with elevations, slopes and everything ? I will add them aswell.
Polyline contours can be used to build surfaces if they have elevations, but yours don't. The only way that you could use these would be to select the polylines one at a time and assign the correct elevation to each.
Edit - I looked at this again and realized that you have text at each point block with an elevation. I was able to use the data extraction tools to build a csv file from those text labels. Import the file to get cogo points, then add those to your surface.
Steve
Thanks, actually i figured that out 🙂 i made my surface using elevation contours. Btw, can u tell me, how you created that csv files, that could help me in future 🙂
All of your elevation text is a standard offset from the point blocks. Move all your text at once so the insertion point of the text is at the insertion points of the point blocks. Then use the MoveTextToElevation command and build the surface from the text.
BTW. The only Surface Style I see in your drawing, Standard, is not set to display contours. You need to import one that does or to edit the Standard Style before you will see contours.
Allen
Allen Jessup
CAD Manager - Designer
A few other things to consider.
Steve
