I am working with my center line profile and I want to make a copy of my profile for my right & left side of the road
so the have the same station but when I copy the profile view and add my FG with profile creation tools
it will show up on the othe original profile I want to have independent profile for my left & right side of the road
Jaime
Do you mean that you would like separate profile views for each of the profiles? The stationing for your profiles comes from the associated alignment. If you are creating a profile with the layout tools, you could even start with an empty profile view.
All profiles generated from a common alignment will be displayed in each profile view that is associated with that same alignment. To control which profile is displayed in any given view, look at the profile view properties and choose the profiles tab. There, you can turn the display of each profile on and off.
If you copy a profile, it will do just that - create an identical copy whch you can then edit with the geometry tools.
Most people (myself included would create a corridor and use an assembly to create the roadway along the road. Unless your alignment is one single tangent and no more, then what you're looking to do won't work. Once you hit a PC or PI then the stations will no longer match up.
Don Ireland
Engineering Design Technician
Joe Bouza
