*Smith, Brian D.
Message 1 of 4 (97 Views)
MTEXT
97 Views, 3 Replies
12-03-2003 10:03 PM
Can anyone tell me why when I try to edit mtext the editor opens but I
cannot see the text. I have to zoom in\out before I can see the text so I
can edit it.
Brian D. Smith
*Hailey, Brian
Message 2 of 4 (97 Views)
Re: MTEXT
12-03-2003 11:14 PM in reply to: *Smith, Brian D.
Brian,
I'll assume you are using Windows XP. Right click on your desktop and
select Properties, go to the Appearance tab and select the Effects... button
and uncheck the Use the following method to smooth edges of screen fonts:
box.
Brian
"Brian D. Smith" wrote in message
news:6DCC28D9F7851FA85F2C0763B650019E@in.WebX.maYIadrTaRb...
> can edit it.
> Brian D. Smith
*Smith, Brian D.
Message 3 of 4 (97 Views)
Re:
12-05-2003 12:04 AM in reply to: *Smith, Brian D.
I am using Windows 2000 and this was unchecked. I checked the box and it
had no effect, still the same problem. It is a real pain to find my text
everytime I want to edit it.
Brian D. Smith
"Brian Hailey" wrote in message
news:3F671A1A6F8003ED8910B2D093F9C92E@in.WebX.maYIadrTaRb...
> Brian,
button
> box.
> Brian
I
> > can edit it.
> > Brian D. Smith
*Rogerson, Michael
Message 4 of 4 (97 Views)
Re: MTEXT
12-11-2003 05:09 AM in reply to: *Smith, Brian D.
Brian,
I know that if you have a layer or object colored 255,255,255 and you are
using a white background (in options -> display tab), the object will not
show on the screen, as it's the same color. However, if you use the object
color "White" instead, it will invert it to black when a white dwg
background is used.
Maybe that's your answer, I don't know!
Mike
> can edit it.
> Brian D. Smith
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
