Civil 3D Forum
MTEXT Field data location
21 REPLIES 21
Message 1 of 22
1283 Views, 21 Replies
Using C3d 2013.
Where do I find the PI data of an alignment object to plug into a mtext Field?
Field Category and Field Name and any other steps to locating it would be helpful.
Adam
21 REPLIES 21
Message 2 of 22
AllenJessup
I don't see where you can get that in to an MText field. I always use a Civil 3D label as shown here:
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 22
in reply to: AllenJessup
Thanks, but I am trying to generate a label that pulls data from multiple objects (an alignment, a pipe network part and the PI).  For example:
PROP. 6' DIA. MH S-1
STA. = 13+23.53
Δ = LT 12°25' 15"
Where 6', MH, S-1, 13+23.53, LT and 12°25' 15" are 6 individual fields.  I figured out most of them, but am having trouble with the deflection angle components.
I posted another question on where to find it under the pipe network part label reference text because that would be just as useful (no response to it yet).  Due to the ease of working with mtext and annotative text, I was hoping to find a solution to both methods.
Adam
Message 4 of 22
Joe-Bouza
C3d does not support fields. Allen is correct to use c3d labels. You can add reference text in a label style to pull from other objects
Joe Bouza
Message 5 of 22
in reply to: Joe-Bouza
Alright, then please tell me where to find the PI's Deflection Angle in the pipe network part's label Text Component Editor.  I don't see it as one of the options under any of the Reference Text types.
Message 6 of 22
Joe-Bouza
I looked close r and see you trouble: reference alignment parameters do not include the delta. you may have to use a seperate alignment label to include these values in plan
Joe Bouza
Message 7 of 22
So what seems should be a simple reference text to a label turns out to be an impossible task for C3D?  I will have to mess with double the labels then?  Or is there a way to append a label to another label?
Everyday, I find a new reason to hate AutoDesk.  Can't wait for ESRI GIS to catch up on the drafting tools.
Thanks for your time Joe.
Message 8 of 22
Joe-Bouza
Now before go off hating c3d - I'm not be be all and end all to what can be done with styles, Unfortunately no one else chimed in.
Since I have your ear and you revealed you lean toward the GIS side. could you explaing to me how to create a multiling label usning the planning and analysis work space?
I used the dialog to add label thinking I only had to add a label for each property but only one property shows?
Joe Bouza
Message 9 of 22
Sorry to have misled you.  My knowledge of GIS is more limited than my C3D knowledge.  I just know the data management tools are a lot more useful, comparing and manipulating data is freely done across any of the data (where C3D restricts it) and the ArcMap program in general has a lot less bugs than C3D.  But the GIS Manager at our office may know.  I'll pick his brain and get back to you.
Our primary client requires drawings in AutoCAD format.  But I think we could convert them if the drawing capabilities were there.  If that were the case, then I might be better suited to answer your question.
I only hate AutoDesk because they repeatedly put out well below standard quality products that continue to crash or freeze or don't function as described in their documentation.  I wish they would just take a year or two and work out all the issues and limitations with their current product instead of adding new features.  Then I could see paying that absurd subscription cost.  Sorry, I rant sometimes.
Later
Message 10 of 22
How do I move the later portion of this post to the other post that identifies the label aspects?  I want this one to go back to the original question posed regarding MTEXT and how to make these notes with fields.
Message 11 of 22
Joe-Bouza
Does it matter? My first response is correct; there is no way (with out programing) to get c3d info int a field.
Cut and paste, but that would be double posting a double post Smiley Surprised
Joe Bouza
Message 12 of 22
wfberry
Deflections are included if you use an Alignment with your pipes.  It is under Label Styles, Tangent Intersection.
Bill
Message 13 of 22
Joe-Bouza
in reply to: wfberry
yes but you can't access it from the structure label style
Joe Bouza
Message 14 of 22
Sorry Joe,
No luck on the multiling labeling in GIS.  Our two GIS guys don't work with labels often enough to know.
Message 15 of 22
Joe-Bouza
Thanks for looking
Joe Bouza
Message 16 of 22
Civil 3D doesn't have a pipe line / structure label like this of label built in.
I would make two labels and place them on together. The structure label would label the size and number, and the aligment label would label the turned angle. I might add a short line seg to the "top" label so that I could snap the "bottom" label into position.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 17 of 22
Thanks Peter
Joe Bouza
Message 18 of 22
in reply to: peterfunkautodesk
Peter,
It appears you are an employee of autodesk.  Could you find out why wouldn't autodesk have labels generated to function similar to mtext?  Be able to add fields to the labels, and make it annotative to improve efficiency of labeling?
They made something that seems very robust, but if the general user can't figure it out intuitively, then it is relatively worthless.  Small companies can't afford the additional training required to optimize this stuff, especially when it can barely afford the subscription.
The work around doesn't work when you have it oriented different in various viewports.
Thanks for the suggestion though Peter.
Adam
Message 19 of 22
Hidden_Brain
Joe,
not sure if I completely grasped your question about multiline label (your question was on ArcGIS or Map 3D?), but are you trying to add labels composed of multiple lines pulling info from different attribute fields in ArcGIS? if so, you may be able to accomplish what you need with VB label expression using the  vbCrLf function. please see attached image for an example, labels the drainage area name, divides the sq.ft area by 43560, rounds it, and labels the arcreage in the second line.
Message 20 of 22
Joe-Bouza
Hi YoungPE,
It the Mad3d I'm working in, I have since gotten into the expression builder, but in 2012 the enhanced label interface added a wizard that does do what I intuitivly expect it to do.
Joe Bouza
Rail Community
