I have several user in my company with issues using Mapwspace.
1. I have imported a Nearmap image, (using command mapwspace) and drawn lines over and around the site, plus added sample points, and notes, and cadastre. These are clearly to be seen when the drawing is loading, but when the image comes in, everything disappears, except for the legend and text in paperspace.
I have replicated this issues and the image disapeared when i created the Vport also?
We are using Civil 3D 2012, SP1, and ideas?
Cheers
You mention that "several" users experience this issue, does this mean that some users do not experience the issue?
Does this happen in all drawings or just one?
What happens when you create a new viewport?
Not sure if this would help, but Update 2 was just released, you should try installing it: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20021271&linkID=9240698
