AutoCAD Civil 3D General
Active Contributor
mikerobe100
Message 1 of 4 (115 Views)
MANIPULATING POINTS
115 Views, 3 Replies
11-19-2013 02:04 PM
I have a background in LDD. It was very easy to move and rotate my points/nodes. Im trying to do the same thing in c3d 2012. i have a group of points that I need to move and then rotate. how can I do this easily? i do not completely understand the prospector/survey tabs? is there a good tutorial somewhere? this transition from 2006 to 2012 is making my brain hurt.
tcorey
Message 2 of 4 (102 Views)
Re: MANIPULATING POINTS
11-19-2013 02:52 PM in reply to: mikerobe100
How do you want to select the points? Is it easy to select on the screen or do you want to pick a Point Group?
If you're going to pick on the screen, just use the regular AutoCAD Move and Rotate commands. If the Poitns aren't locked they will move like any other object.
If you have a Point Group you want to move, go to the Prospector tab, right click on the name of the Point Group and pick Select. That will select them on the screen. Now use Move or Rotate as needed.
Best regards,
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Distinguished Contributor
nmessina
Message 3 of 4 (93 Views)
11-19-2013 03:18 PM in reply to: mikerobe100
What type of points are you talking about? Are they simple COGO Points or are they SURVEY POINTS from a Survey Database (i.e. Data Collector)?
Nicholas, Messina Jr.
Valued Contributor
g_k50
Message 4 of 4 (88 Views)
11-19-2013 03:25 PM in reply to: mikerobe100
rotating a network of points to a known bearing or asimuth from an assumed one can be accomplished on the Survey tab of Toolspace
Right click the database that needs translation
Select the Translate Survey Database, you can select the base point, rotation angle, destination point
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
