I know I'm supposed to forget everything I knew about Land Desktop. But...
...there are two functions that I would think are still there, but I cannot find them or remember their names.
1) One was a scale/rotate command that scales and rotated blocks. You could pick multiple blocks and scale and rotate them together, only centered around each individual insertion point. It was in the same menu as the Flatten function, if I remember correctly
2) I used to routinely use a list command that would give a simple bearing/distance line information or curve information. It was not the common LIST command, it was something specific to LD, if I remember correctly.
Can anyone help me?
@Maine-iac wrote:The other option for listing line and arc info, if your preference is picking icons than typing CGLIST, is to go to Analyze tab on command ribbon, look for the "Inquiry" grouping of icons, in 2011 there is a small icon within the group of 12 that looks like an arc with 3 dots and a small ruler, it is "Line and Arc Information", it does same as CGLIST. If you are a surveyor this icon would be better if moved or copied to your Home tab or put on the Quick access toolbar for routine use.
Since I first started this thread I have found that command, and it works beautifully. I added it to my quick access toolbar and use it all the time.
Actually the commands are already in Civil 3D. Try typing in at the the Command line:
BSCALE and TSCALE.
K
