AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 6 (283 Views)
Lossing my contours in Civil3D 2013
283 Views, 5 Replies
12-18-2012 01:51 PM
Hi:
I have build a surface definded by polylines but time to time I lose the contours generated by the surface. I lost them when I re-open the file after closing it the day before or in other commands like save. I am Windows 7 user, 64 bit so I am not sure if some one else have had this problem. Maybe I have to check my RAM perhaps?
Thanks in advance
Rafael
neilyj
Message 2 of 6 (280 Views)
Re: Lossing my contours in Civil3D 2013
12-18-2012 01:52 PM in reply to: RafaelMoreno
Do you have Level of Detail switched on?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Message 3 of 6 (263 Views)
12-18-2012 02:47 PM in reply to: neilyj
Hi:
Thanks for the answer. I do not what is level of detail so I am not sure if I have it turned on or off. However I think that it is not the problem due I lose contourse for one of the surfaces that I have in the screen. The other one that defines my dams are intact
Rafael
BrianHailey
Message 4 of 6 (242 Views)
12-18-2012 08:54 PM in reply to: RafaelMoreno
Level of Detail can be found HERE.
neilyj
Message 5 of 6 (235 Views)
12-19-2012 12:06 AM in reply to: RafaelMoreno
If you see this,
then it is switched on; if not, then post the dwg
neilyj
Message 6 of 6 (215 Views)
12-19-2012 02:06 PM in reply to: RafaelMoreno
Hi:
Thanks for the instruction. I am keeping my contours by now. I hope to follow up just in case I have this problem again. The lavel of detail commna is working by now.
Cheers
Rafael
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
