Hi:
I have build a surface definded by polylines but time to time I lose the contours generated by the surface. I lost them when I re-open the file after closing it the day before or in other commands like save. I am Windows 7 user, 64 bit so I am not sure if some one else have had this problem. Maybe I have to check my RAM perhaps?
Thanks in advance
Rafael
Solved by neilyj666. Go to Solution.
Do you have Level of Detail switched on?
Hi:
Thanks for the answer. I do not what is level of detail so I am not sure if I have it turned on or off. However I think that it is not the problem due I lose contourse for one of the surfaces that I have in the screen. The other one that defines my dams are intact
Rafael
If you see this,
then it is switched on; if not, then post the dwg
Hi:
Thanks for the instruction. I am keeping my contours by now. I hope to follow up just in case I have this problem again. The lavel of detail commna is working by now.
Cheers
Rafael
