Civil 3D Forum
Looking for a way to capture the drag distance of a label...
5 REPLIES 5
tcorey
199 Views, 5 Replies
Hello all,
Does anyone know a way to capture the drag distance of a Civil 3D label object?
If that was a property, then we would be able to make our Leaders display or not display based on the distance from the object. If I only drag a label a half-inch I might not want a leader, but if I go further I would like the leader to appear.
It would be easy enough to do this with expressions if you could make that property available in the expressions dialog.
Thanks in advance for any ideas,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
5 REPLIES 5
Jeff_M
in reply to: tcorey
Tim, C3D2013's .NET API provides the necessary Label object properties to do this programmatically. Can't think of any other way, other than manual visaul inspection, right now.
Jeff_M, also a frequent Swamper
tcorey
in reply to: Jeff_M
That's what I figured. Thanks, Jeff.
Tim
Tim Corey
Redding, CA
Jeff_M
in reply to: tcorey
Actually, I found that working with cogopoints is a bit different than most labels. Here's a quick video of the what can be done though:
http://screencast.com/t/iPz6sngUA
For this I used the Point.Location and Point.LabelLocation properties to determine whether to use the leader or omit it.
tcorey
in reply to: Jeff_M
That's a custom routine, right? You're not accessing Point Labellocation other than through .Net?
Tim Corey
Redding, CA
Jeff_M
in reply to: tcorey
Correct, Tim. Programming only.
Rail Community
