My tool pallettes have a red circle with a crossbar upon using the left click and the MOVE is greyed out on the right click menu. They’re stuck in place!
I’ve gone through the OPTIONS and don’t find a setting. I've also run a software repair and rebooted.
Is there another answer? Hoping there is.
SYSTEM:
WIN7
C3D 2012 (Autocad 2012 Certified Professional User)
24 GB RAM
Solved by MarySeufert. Go to Solution.
You have locked your floating tool palettes. Either press and hold the 'Ctrl' key while moving/resizing them or change the settings by picking the lock button on the status bar menu.
~ Mary
Thank you Mary. That was the ticket! I did not know to use that LOCK icon in that manner. Whew-finally!
Mary Beth Harwood
