Civil 3D Forum
Loading Shapefile attributes into AutoCAD
2 REPLIES 2
2279 Views, 2 Replies
I'm using AutoCad 2013 Civil 3D. I'm trying to import the attribute table from a GIS shapefile into AutoCAD.  I tried it in Map but could not get it to work.  I could not find and object file in creating a quirey.  Is thier some online documents that could help me out.  I'm new to AutoCAD so any simple help would be appreaciated.
2 REPLIES 2
jporter
You must first import the GIS data into a drawing, save the drawing, and then attache that drawing into your working drawing.  Once attached, you can query in the data you need.
Here's a video I put together that explains how to do this:
http://enceptia.com/importing-gis-data-civil-3d/
Watch the whole video before you jump in.
This is just one method.  You can also use this method if you choose:  http://www.augi.com/library/gis-to-cad-in-civil-3d
Hope this helps,
Jason
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
andrewpuller3811
Try here http://docs.autodesk.com/CIV3D/2013/ENU/filesMAPC3D/GUID-8503FBE6-B094-4E8B-847F-B6787B674200.htm
The online help for Civil 3d 2013 is here http://docs.autodesk.com/CIV3D/2013/ENU/
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
