Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Linking Parcels to EXCEL
3 REPLIES 3
dave
932 Views, 3 Replies
Here's what I'd like to do:
Create a large number of polygons (plines, parcels, whatever) that represent spaces on a building plan
Assign a space number to the polygon
Link the space number to an Excel spreadsheet (or Access DB) so that the characteristics of the polygon (line and fill color, for example) are chosen based on the "owner" of the space (e.g.; Engineering, Common Areas, etc.).
Display a label stating the space number and the space name.
Is this best done with "Parcels" in Civ3D, or with "Polygons" in Map, or some other way.
Thanks.
3 REPLIES 3
thepworth
in reply to: dave
I'd say polygons (polygon topology) in Map - you end up creating "centroids" for each parcel/polygon and then link the exel data (ODBC FDO connection) to Civil/Map
Neilw_05
in reply to: dave
You might want to consider the _ADEGENLINK command in Map.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
antoniovinci
in reply to: dave
All you want is easily doable in Map, but the quoted in red, unless writing Lisp code...
Rail Community
Ā
Ā
