Link slope to surface subassembly wil not reflect info from the Superelevation info properly. You have to toggle cut and fill to get to show proper rotation. Leaving set to "cut and fill" should work for all because the slope should be coming from SE info (when left set to 'cut and fill" it shows the opposite of what it should show, ex if slope is supposed to be -6% from SE info it draws at 6%). I tested the linkwidthandslope subassembly and it reads the SE info fine and rotating as to be expected, although i need an assembly to target a surface and also rotate properly.
What version of Civil 3D are you using?
Would you be willing to upload your drawing so I could take a look at it?
If it is too big to post here, please let me know and we can make other arrangements to get me the data.
M,
From the Help Section:
Superelevation
"If you are adding superelevation to any alignments, do so before creating the corridor. Also, the superelevation data is not dynamic, so it does not update if you grip-edit the alignment. Therefore, add the superelevation after the alignment design is stable, or be prepared to redo the superelevation if the alignment is modified."
Are any of these a possibility?
Dave
Dave Stoll
Las Vegas, Nevada
