I am trying to figuere out how to use the link to marked point subassembly. I am trying to link a back of curb to a sidewalk that varies in distance to the centerline to my corridor.
I tried using the Help menu and searched this forum on how to do this, but to no avail.
I have assembly created.
I have an additional edge of sidewalk alignment & profile created.
Can anyone give be a good step by step on how to add a sidewalk SA with a link to mark SA to my existing Assembly: so that the sidewalk links to the sidewalk alignment & profile?
Do add and name a MarkPoint SA to my Curb SA. Then add a LinkToMarkedPoint SA to the MarkedPoint SA, then add a Sidewalk SA to the LinkToMarkedPoint SA? I can't seem to get all these things linked together.
P.Graf
It may be a better solution to use sub-assemblies other than the "Link to Marked Point. From the back of curb I would add a "link offset and slope". This sub-assembly will allow you to set alignment and profile targets. Then add the urban sidewalk subassembly. I have created similar assemblies and used them with success.
(The "link to marked point" sub-assembly must have a corresponding "marked point" sub-assembly and their P Codes must match exactly.)
Jessica
Thank you. Now that I read your reply it sounds like the most obvious solution. ie.. why didn't I think of this?
I 've used the linked offset & slope SA many times, but the whole marked point & pcodes thing still befuddles me.
I going to try the LinkOffsetAndElavation SA. Since my slope varies
