I'm sure this has been discussed and I just didn't pay attention at the time.
I am re-routing a small stream. I am using generic links for the bed and side slope. I whant the side slope to be 3:1 and project beyond the existing culvert wall in the eg model. can this be done easily?
Your Name
Your Name
Solved by fcernst. Go to Solution.
Use DaylightMultiIntercept with InterceptNumber set to 2.
Your Name
Your Name
I have a LinkSlopeToSurface subassembly part and I don't see an Surface Target choice anywhere. The Subassembly help says there is one. Do y'all know where this is?
the surface is assigned in the corridor not the assembly.
Corridor properties >> set all targets
Your Name
Your Name
Thanks for your reply. I set that. My situation is I have an assembly with two slopetosurface links. I would like one to target on surface and the other a different surface.
Ahh.
My issue was one surface with multiple intercepts in your case there is another daylight sub called daylight multiple surface
Your Name
Your Name
