When I use link offset to surface and attach on left side, still extend to right. I am targeting a slope stake line polyline that exists on both sides of the roadway, works fine on right side. Documentation indicates that a negative offset value is needed to use to the left. How do I use negative value and target a polyline?
model (1) is the result on the left
model (2) is the correct result on the right
Stanley
Solved by jmayo-EE. Go to Solution.
I don't think you will get the target correct with a closed pline. Try one target pline right and one target pline left if you have a closed pline.
John Mayo
