Any advice Please
Post your drawing...
Try checking your Front Clip and Back Clip distances in the section editor, in View/Edit Options.
Mine are set to 0.1 and -0.1.
Thank you Mr.Andrew for your effort.
As you can see in attached file iset all thing as your setting but nothing happen.
I think my issue here as you can in attached file there are additional subassemblies(fake) beside my original one and let me tell other station had a link code and everything was ok because there weren't any additional subassemblies.
May if you haven't any idea i will post my DWG.
Thank you.
I figure out an issue and let me explain what happened.
Additional subassemblies(fake) appeared at hairpin location only
As you can see in attached file i have a hairpin in my project
For your Advice
Thank you
In the section editor, you can use the "Viewport Configuration" command on the "View Tools" tab to set the view to show the plan and section (and the profile) which might have shown this a a bit earlier.
Dear Mr.Tim,
Can you give your email because i can't upload more than 1.5Mb here in this forum
Thank you.
Dear Sir,
You can download my file that describe my issue from the following link:
Your files are ready to be downloaded by your recipients
Thank you Mr.Brian for your reply,
When i looked to your system i found that you have 2013 version after that i open my DWG with that version and i finally got my issue that 2012 version had some bugs.
What i'm lookin for what about the earth work quantity if you looking to overall corridor section editor you will see some additional bugs in link code as you can see in attached file
For your advice.
Thank you.
