AutoCAD Civil 3D General
Distinguished Contributor
onsionsi1
Message 1 of 11 (488 Views)
Link Code Hidden in Corridor Section View
488 Views, 10 Replies
11-24-2012 10:01 PM
I have a problem with editing in link code because it didn't appear in corridor section view as you can in attached files.
And i think the problem appeared because there were some additional subassmbly (not original Subassembly) beside the original Subassembly and i also checked my sample lines and it didn't intersect alignment twice as if you think it intersected alignment.
Any advice will be appreciate
Thank you.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
onsionsi1
Message 2 of 11 (457 Views)
Re: Link Code Hidden in Corridor Section View
11-26-2012 03:04 AM in reply to: onsionsi1
Any advice Please
tcorey
Message 3 of 11 (444 Views)
11-26-2012 11:42 AM in reply to: onsionsi1
Post your drawing...
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Distinguished Mentor
andrewpuller3811
Message 4 of 11 (434 Views)
11-26-2012 05:46 PM in reply to: onsionsi1
Try checking your Front Clip and Back Clip distances in the section editor, in View/Edit Options.
 Mine are set to 0.1 and -0.1.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
onsionsi1
Message 5 of 11 (412 Views)
11-27-2012 10:13 PM in reply to: andrewpuller3811
Thank you Mr.Andrew for your effort.
As you can see in attached file iset all thing as your setting but nothing happen.
I think my issue here as you can in attached file there are additional subassemblies(fake) beside my original one and let me tell other station had a link code and everything was ok because there weren't any additional subassemblies.
May if you haven't any idea i will post my DWG.
Thank you.
onsionsi1
Message 6 of 11 (402 Views)
11-28-2012 03:07 AM in reply to: onsionsi1
I figure out an issue and let me explain what happened.
Additional subassemblies(fake) appeared at hairpin location only
As you can see in attached file i have a hairpin in my project
For your Advice
Thank you
andrewpuller3811
Message 7 of 11 (380 Views)
11-28-2012 02:20 PM in reply to: onsionsi1
In the section editor, you can use the "Viewport Configuration" command on the "View Tools" tab to set the view to show the plan and section (and the profile) which might have shown this a a bit earlier.
Andrew Puller
Civil 3d 2013 64bit
onsionsi1
Message 8 of 11 (339 Views)
01-01-2013 02:21 AM in reply to: tcorey
Dear Mr.Tim,
Can you give your email because i can't upload more than 1.5Mb here in this forum
Thank you.
onsionsi1
Message 9 of 11 (336 Views)
01-01-2013 03:19 AM in reply to: onsionsi1
Dear Sir,
You can download my file that describe my issue from the following link:
Your files are ready to be downloaded by your recipients
Download expiry date:Friday, January 04, 2013 12:17 PM
Download limit:10 times
Password:-
Link to download page:
https://www.filemail.com/dl.aspx?id=SZQQQEHTHZQGNAO
BrianHailey
Message 10 of 11 (304 Views)
01-02-2013 07:38 AM in reply to: onsionsi1
The drawing you shared the links show up just fine on my system. You can see it HERE.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
