Active Contributor
ADRooney
Message 1 of 5 (469 Views)
Lines to Northing Easting elevations
469 Views, 4 Replies
03-31-2013 12:50 PM
How to convert these text to polylines. And extract points.
Alfred.NESWADBA
Message 2 of 5 (463 Views)
Re: Lines to Northing Easting elevations
03-31-2013 01:44 PM in reply to: ADRooney
>> And extract points.
On one side I assume it's a crosspost to >>>that message<<<
Also your questions are to short to know what you really mean. Tell us more about what you like to do as I don't think you really want to convert the text to polylines (resulting in the outlines of each character are then drawn as polyline, which could be done by command _TXTEXP from express tools).
What do you mean by "extract points", what points should be "extracted" and what result do you want to achieve.
- alfred -
Alfred NESWADBA
BrianHailey
Message 3 of 5 (446 Views)
03-31-2013 04:18 PM in reply to: ADRooney
If you only have a few pieces of text you want lines drawn through, just snap to them (either NODE or INSERT snap).
As for "extracting points", I would guess a data extraction would work.
Active Contributor
ADRooney
Message 4 of 5 (422 Views)
04-01-2013 01:16 AM in reply to: ADRooney
Thank you for the reply.
If you see the text properties they have X Y values. So do they resemble the northing easting positions.
So my question is how to insert a point at those text and create a point group ?
Alfred.NESWADBA
Message 5 of 5 (417 Views)
04-01-2013 01:28 AM in reply to: ADRooney
run command _DATAEXTRACTION, the result of that is an ASCII-file, then use the C3D-command _AECCCREATEPOINTS (7th icon in the tool) to import points from that ASCII-file.
- alf
Alfred NESWADBA
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
