Valued Contributor
asloat
Message 1 of 6 (119 Views)
Lines not printing behind screen
119 Views, 5 Replies
01-17-2013 05:44 AM
Has anyone seen this before and possibly know a solution?
I have a drawing with a screen and behind it is an xref drawing. When I print it to our KIP plotter the lines and other items behind the screen do not plot.
Here is how it is setup and what I have tried
The Xref itself is on its own layer and all the layers of the xref are set to a color that has thickness of .0138 and a 35% screen.
The hatch resides in the active drawing and is set to a color that is also .0138 thick but at a 20% screen.
The hatch is a DOT hatch at scale 1, but I have also tried it as a solid hatch
Lines merge is on and needs to be on.
I have made sure that the hatch is sent to the back and that there is no overlapping of data from other sources liek a second hatch or the same data in another xref etc.
I also tried setting the xref layers to another color that is .0256 thick with a 35% screen, but the results where the same. If i change the xref layers to a .0138 thick color with 100% screen, they do print over the hatch then.
I have also found that if I use the same plotter but with a post script drive, it does work as setup, though that creates other issues that are not ideal.
TRogers
Message 2 of 6 (113 Views)
Re: Lines not printing behind screen
01-17-2013 06:24 AM in reply to: asloat
In the plotter settings, do you have it set to Lines Overwrite, or Lines Merge?
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
asloat
Message 3 of 6 (111 Views)
01-17-2013 06:33 AM in reply to: TRogers
We use "lines merge" for a variety of reasons, though I need to toggle it on each time I plot as we are not currently using PC3s.
TRogers
Message 4 of 6 (110 Views)
01-17-2013 06:34 AM in reply to: asloat
You might want to try Lines Overwrite.  See if that works...
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
asloat
Message 5 of 6 (109 Views)
01-17-2013 06:36 AM in reply to: TRogers
Lines overwrite is not an option for my company.
Member
g.diazfonseca
Message 6 of 6 (100 Views)
01-17-2013 07:41 AM in reply to: asloat
There is not much different between 20% and 35% screen. Try using a 40% or 50% instead, also if the hatch is in his on layer assign a transparency value to it (that may help, but turn on transparency on the plot settings)
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
