I am haveing a problem with a scaling (in viewport) a line table. Whenever I set the scale and regenerate the viewport the tables get movied on top of each other. Any ideas on a solution?
Trent Williams
Gardner Engineering
Easiest way to avoid this issue is, when you first create your table, make sure your scale in modelspace is set to the same scale you want to use for your paperspace viewport. Then the table will be drawn correctly.
If you've already created the table, then note the viewport scale of the paperspace viewport containing your table. Then switch to modelspace, and change the scale in the Status Bar (lower-right portion of the screen) to match your paperspace viewport. Select the FIRST stack in your table, right-click -> Realign Stacks. (Note that this will not work unless you select the FIRST stack in the table.) You can now change your modelspace scale back to its previous value (if you wish). Your table should now look correct in your paperspace viewport.
