When I draw a line segment I am getting zero elevations even though I am snapping to nodes with elevations. Why is this
When I click on the nodes the properties says they have elevations but the lines don not snap to the elevation. Reset osnapz to "1" still not getting elevations.
Thanks for the reply
Try doing an ID on the node to verify the elevation.
Allen
Allen Jessup
CAD Manager - Designer
You're very welcome. Please mark it as the solution to your question so that others can find a solution to the same problem quickly.
