AutoCAD Civil 3D General
Message 1 of 7 (386 Views)
Lidar Tutorial - Problem with Style Selection
386 Views, 6 Replies
05-31-2012 12:43 PM
In the Tutorial: Working with Point Clouds, Exercise 2 choosing the point style "Lidar Point Classification" doesn't change anything.  I should be seeing the points colored according to classification but instead all points just revert to gray.
Product Support
Matt_Haokip
Message 2 of 7 (355 Views)
Re: Lidar Tutorial - Problem with Style Selection
06-05-2012 01:37 PM in reply to: robert.thomson
Hi Robert,
It appears that you might have missed one of the steps in the tutorial as I do not see any issue with it, after applying the point could style, the program shows all the elevation ranges based on the color scheme.  Make sure that you select Elevation Ranges for the Point Cloud Style within the Information tab and Apply and from the Elevation Ranges tab, you click Reset from style and Apply and OK to the window.
Below is the link to the screenshot of my Civil 3D 2013: http://www.screencast.com/t/RVqBKbXfrLm
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Matt Haokip
Message 3 of 7 (337 Views)
06-07-2012 07:37 AM in reply to: Matt_Haokip
It's not the Elevation Ranges style I'm having problems with.  It works just fine.  It's the Lidar Point Classification style.
I'll try and run through the entire exercise sometime soon but we are quite busy here.
randcdavidson
Message 4 of 7 (265 Views)
10-25-2012 11:37 AM in reply to: robert.thomson
Robert. Ever get an answer to this? Saw that it was back in June then the Autodesk Tech bailed on the problem. I have had the same issue with the Lidar classification color not working.
Message 5 of 7 (251 Views)
10-26-2012 06:20 AM in reply to: randcdavidson
No, I didn't. Glad to know it's just not me!
Active Contributor
Message 6 of 7 (192 Views)
12-11-2012 08:24 AM in reply to: robert.thomson
Yeah Autodesk definitely dropped the ball on this one.  It'd be something if it hadn't worked in 2012, but it did.  Now whenever I have to do LiDAR work, I have to go back and use 2012.  Autodesk, hopefully you get your stuff straight for 2014
New Member
Message 7 of 7 (157 Views)
01-01-2013 03:30 PM in reply to: jeremy.2012
I don't see the LIDAR Point Classification, Point Cloud Style working either, just grey no color variation. Yes the Elevation Ranges, Point Cloud Style display correctly but not LIDAR. So point clouds are not fully supported in Civil 3D 2013? Frustrating tutorial.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
