Distinguished Contributor
csevers
Message 1 of 10 (1,206 Views)
Level of Detail View
1206 Views, 9 Replies
05-29-2013 03:10 PM
How can I turn it off permanently? Or change the default to off? It's always on when I open my drawings.
I save the files with it off, but when I reopen, it's still on. A real pain in the butt when plotting since if I batch plot, all of my contours are off, which eliminates using batch plot entirely. Luckily, I only have 5 figures at the moment, but once we get to design phase I will have many more and require batch plotting.
I'm using civil3d 2013, I have never run into this before with any other versions.
Chris Severs, EI
Windows 7 x 64 bit
NVidia Quadro 2000 Dual Monitor
6.00 GB RAM
Intel Xeon W3550 @ 3.07 GHz
Civil 3D 2013 SP 2, Civil 3D 2012 SP2, Civil 3D 2011 V3, Civil 3D 2010 V3
neilyj
Message 2 of 10 (1,187 Views)
Re: Level of Detail View
05-30-2013 12:08 AM in reply to: csevers
I've never noticed this issue, mine is turned off and stays off.
Clutching at straws a bit but is it on in your template?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Tom_Berning
Message 3 of 10 (1,175 Views)
05-30-2013 05:48 AM in reply to: csevers
The Level of Detail is only used for viewing. When you plot a drawing, the full detail of all objects is plotted no matter how they appear on the screen. Batch plotting should still work.
Tom Berning
Woolpert, Inc.
Civil 3D 2013
wfberry
Message 4 of 10 (1,140 Views)
06-02-2013 10:12 AM in reply to: csevers
View tab -> Views panel -> Level of Detail.(select)
This should turn it OFF or ON.
Bill
csevers
Message 5 of 10 (1,131 Views)
06-02-2013 11:43 AM in reply to: csevers
Yes, I agree that does turn it on and off.
However, no matter how I save the drawing, with level of display on, or off, when I open the drawing, there are no contours displayed whatsoever, no matter how close I zoom, and the level of display is always on. Then when I turn it off, the contours come on. Then if I turn the level of display back on, it works correctly. If I save at this point, close the drawing, and open it again, it all starts over with no contours displayed at all.
Chris Severs, EI
Windows 7 x 64 bit
6.00 GB RAM
sboon
Message 6 of 10 (1,117 Views)
06-02-2013 07:39 PM in reply to: csevers
Sounds like there might be a problem with your installation, or maybe an error in your template drawing.  I turned off this setting long ago, and never had any trouble with it after that.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
csevers
Message 7 of 10 (930 Views)
11-05-2013 12:28 PM in reply to: sboon
I'm still having the same issue. I think it may be due to the size of the surface, it's about 1,000,000 points. It's about 4 square miles, I didn't think that was that large, maybe I'm wrong.
Chris Severs, EI
Windows 7 x 64 bit
6.00 GB RAM
AllenJessup
Message 8 of 10 (921 Views)
11-05-2013 01:38 PM in reply to: csevers
That's fairly large. Can you break it up into sections?
Allen Jessup
csevers
Message 9 of 10 (918 Views)
11-05-2013 01:43 PM in reply to: AllenJessup
Will it help to have multiple smaller surfaces instead of one big one? They will all still need to be in one base drawing. Currently, I have two surfaces (one is approx. 250,000 points, the other is approx. 750,000).
Chris Severs, EI
Windows 7 x 64 bit
6.00 GB RAM
AllenJessup
Message 10 of 10 (916 Views)
11-05-2013 01:45 PM in reply to: csevers
I'll try to get back to you on that. End of the day here.
Allen
