Rick Jackson
Survey CAD Technician VI
Allen Jessup
CAD Manager - Designer
Hi There,
I am wonderin if you have come up with any solution to the matter?
We are very frustrated when resections in the field have so many errors in the fbk file?
Any help is appreciated.
Regards
Allan
To use all of the capabilities of the instrument you need to use LGO (LeicaGeo Office) to process the data. The *.rw5 and *.fbk file formats are from TDS and Softdesk in the mid 1980's the software does not understand the capabilities of modern instruments. To use the free station methods (Smart Station GPS, Resections, mixed GPS and TPS) you need to use the instrument manufactures software. Process and adjust in LGO and export in PXYZDA..csv format and import into C3D and apply description keys. CODELISTS in instrument and in C3D must match exactly for point codes and line work.
Or you can process the data in the instrument and export a point file. (But you can only edit Control Points)
The Softdesk engine processes a simple Plate Angle Survey. It does not understand mixed TPS and GPS surveys, Resections, Reciprocal Leveling, Solar Leep Frog, Triangulation.
Jim
AC3.0 - IDS 2015, LGO8, Move3
Leica System 1200 TCR1200P+SmartStation, GPS1230gg Rovers and Base
Matrix3DSurveys
LeicaGeo Office
Right there is my problem they have locked everything to buy this it will solve your problem........
Not necessary with standard US methods
Rick Jackson
Rick Jackson
Civil3D comes out each year with updates and extras (none that i can think of in the survey package), surley it would be in Autodesks best interest to keep up with the Technology of the instruments......A no brainer to me.
