Civil 3D Forum
Left/Right Sample Profile not Honoring The Gutter
13 REPLIES 13
Message 1 of 14
ToddRogers-WPM
315 Views, 13 Replies
When creating a profile with right/left samples, the sampled profile does not show the gutter when crossing an intersection.  If you do a quick profile of the area, it shows the gutters.  See images below...
Sampled profile...
Same area with a quick profile...
Todd Rogers
13 REPLIES 13
Message 2 of 14
Can you post up the drawing?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 14
Message 4 of 14
Which alignment? What station?
GEI Consultants
My Civil 3D Blog
Message 5 of 14
All of the areas where there is a crossing street.  It's the centerline alignment sampling 30' right and left, but it's just a straight line when it crosses over a street.
Todd Rogers
Message 6 of 14
I can confirm the results you are seeing and it appears to be a bug to me. Have you tried it in 2013?
GEI Consultants
My Civil 3D Blog
Message 7 of 14
Yep.  Same result.
Todd Rogers
Message 8 of 14
I think it has something to do with the curves. If I create an alignment from just lines in the same area, it works just fine.
GEI Consultants
My Civil 3D Blog
Message 9 of 14
Yeah I did that too.  Pretty crappy.
Todd Rogers
Message 10 of 14
sboon
in reply to: ToddRogers-WPM
I tried drawing a simple polyline on the profile view using the SSE transparent command.  It looked OK, so then I created an offset alignment, cut a surface profile on that and then superimposed it back onto the centerline profile view.  That looked fine also, so it's a workaround for the moment at least.
Steve
Expert Elite Alumnus
Message 11 of 14
mathewkol
Well isn't that special.  Same problem here.  Did you create a support request with Autodesk?
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 12 of 14
sboon
in reply to: mathewkol
Wait a minute - was this drawing originally created in 2013 or 2014?  Is it possible that the round trip from one version to another and back again is a problem?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Message 13 of 14
ToddRogers-WPM
in reply to: sboon
No round trip issue.  The customer uses 2013 and I did a WebEx with them and saw the issue.  Had the customer send the drawing to me and same thing happened in 2014.
Todd Rogers
Message 14 of 14
ToddRogers-WPM
Not yet Matt....going to this morning.
Todd Rogers
Rail Community
