AutoCAD Civil 3D General
yazzie91
Message 1 of 8 (250 Views)
Accepted Solution
Leader vertex does not connect to line when changing scales
250 Views, 7 Replies
11-15-2012 04:12 PM
I’ve had this problem with my proposed elevations for quite some time so I finally want to fix it while I’m a little slow. The problem I have is when I change scales, my elevation’s (in dragged state) leader vertex does not connect to my line. I’ve attached my lable styles so hopefully someone can give me a few pointers.
*Expert Elite*
BrianHailey
Message 2 of 8 (230 Views)
Re: Leader vertex does not connect to line when changing scales
11-15-2012 06:33 PM in reply to: yazzie91
Post up a drawing with the style so we can take a look at it.
Or, if you would rather, you can send it to me directly. I have a gmail account named c3dplus you can send it to if you want.
yazzie91
Message 3 of 8 (212 Views)
11-16-2012 07:52 AM in reply to: yazzie91
Here it is
*Expert Elite*
Joe-Bouza
Message 4 of 8 (207 Views)
11-16-2012 08:00 AM in reply to: yazzie91
Nice looking plan.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
yazzie91
Message 5 of 8 (205 Views)
11-16-2012 08:07 AM in reply to: Joe-Bouza
Joe-Bouza wrote:
Nice looking plan.
Thanks........I hope that's not sarcasm.
I made the jump from 2000 LDD to Civil 3D about 18 months ago and still trying to perfect my styles.
*Expert Elite*
Joe-Bouza
Message 6 of 8 (197 Views)
11-16-2012 08:30 AM in reply to: yazzie91
I must have a rep.
Nope I was genuine :smileywink:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
Jeff_M
Message 7 of 8 (190 Views)
11-16-2012 08:59 AM in reply to: yazzie91
You need to use some different techniques. Right now it appears you are moving the leader vertex when the label is dragged to the left. When you change scales, the leader's vertex remains where you moved it to.
 Here a couple ways to address this:
Set the label style's dragged state to Stacked Text, where upon you lose the line in the label but at least the text will flip to the correct side.
Create a child style, but have it initially go to the left. Then you will use both styles for the labeling, one for the right offsets and one for the left offsets. Attached are 2 images for 10 & 20 scale using this method:
yazzie91
Message 8 of 8 (184 Views)
11-16-2012 09:33 AM in reply to: Jeff_M
Thanks! I was hoping I could do it all in one style, but this will work fine.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
