I have saved view names for the sheets of sections to plot sheet 1 - 7, Then I created the layout tabs 7 set to plot on 24x36 paper, and 7 to print in color on 11x17. When I create the single viewport in the layout tab and then select the view name to set as current hit ok then pick the viewport frame and I have my sections as they are on the dwg. Now I plot them and the text disappears. can anyone tell me how to fix this. a coworker has used several dws to make this current dwg. I have made layouts like this before without any problems. once this is fixed the layouts can be plotted in publish.
