I use SAC 2014 to create a subassembly such as following but when design, the next Subassembly doesn’t attach with point P4, while the terms verify as designed is TRUE.
I checked and found that the Layout mode is diffirent with- the Roadway mode.
Please help to my problem.
Thank everyone!
Solved by nestxanh. Go to Solution.
Roadway mode considers all of the targets and Layout mode does not. Layout mode is what it will look like when you insert the subassembly onto an assembly in Civil 3D. If it is important for you to see this point in layout, try fiddling with the Miscellaneous Properties in your points and auxiliary points where you can specify a DeltaX for Layout mode, or you can fake the logic in layout mode by using the API function SubassemblyName.IsLayout
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Thank KMercier_C3D very much!
I used API function SubassemblyName.IsLayout and have solved my problem.
Thanks again!
you can use it with a decision using this expression.
although you can also use the expression in the following way if you are a slightly more advanced user
