hello,
i've problem, i had moudified the template of plan and profile and i had added a new layout inside this one
but when i try to create viewframe using the viewframe wizard under the sheets tab i dont find the last layout wich i had created
in this image i show the new created layout
and here when i try to use the same modified template to create viewframe from sheets tab of the viewframe wizard
Solved by klugb. Go to Solution.
Go back to the template and look at the viewports you have for that layout. If you don't have one defined as "Plan" and one as "Profile" it won't show up on the list.
No problem,
Now if ADSK would give us the Plan/Plan option in the view frame/Create sheets creation I would be happy.
I know there are workarounds but a standard option for it would be good.
