Gene Daspit wrote:
> I am trying to lay out a profile with verticel curve. When I go to the
> Profile Layout tools, I set the length of curve and then select Draw
> Tangents with Curves. When I draw my profile in, it isn't drawing the
> curves in.
Gene,
First thing to check is if your OSNAP settings are on. If they are and
the profile layout tool is snapping to a point that's less than the
length of the parabolic curve that you set up, then there's no solution
for that, and you will get tangents without curves.
Even if your OSNAP isn't on, the length you have set must be
met/exceeded for the curve to be drawn in. You can test this by going
out a distance longer than the length and making sure that that you can,
in fact, see the curve being drawn.
> I have gone to Edit Profile and selected Panarama. When I go
> there to edit the profile, the Grade Change is grayed out and I am
> unable to edit the Legth of Curves.
When you went to Panorama, did you see that a curve has been created?
Look in the column entitled "Sub-Entity Type" and you will see
"Symmetric Parabola" where a curve segment was added. If it's empty,
then no curve was able to be fitted there.
The Grade Change column is read-only; you cannot edit values in that column.
> I am using Civil 3D 2005 SP 1.
Is it possible that you could upgrade to Civil 3D 2006 SP1 instead of
staying on 2005? There are so many enhancements and fixes that you
would really benefit from using the current version.
Himanshu Gohel. Civil3D Team, Autodesk, Inc.
Autodesk Civil3D Product Information: http://www.autodesk.com/civil3d
