Civil 3D Forum
Layer states will not hold
37 REPLIES 37
Message 1 of 38
Joe-Bouza
1475 Views, 37 Replies
in 2012 I saved a layerstate and it shows in the dialog but if I change the stet to another and go back none of the settings are held. Is this a known problem?
Your Name
37 REPLIES 37
Message 2 of 38
AllenJessup
in reply to: Joe-Bouza
Joe,
Do you have the "Apply properties as viewport overrides" box checked?
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 38
Joe-Bouza
in reply to: AllenJessup
Hi Allen
Yes it is checked
Your Name
Message 4 of 38
AllenJessup
Are you trying to apply the layer state as viewport overrides? If so. You'd have to be in an active viewport for them to take effect.
I just want to make sure that's what you're doing.
Allen
Allen Jessup
Message 5 of 38
Joe-Bouza
Specifically, no I am not trying to set vport layers, but I tried both checked and unchecked. All I am doing setting my global freeze thaw >> add a new layer state>> name it>> close>> reset the other state>> then try to reset the new one and nothing is frozen?
Also, Did have the overide check box hose me? all the lines are blue like I have a vport saved.
Your Name
Message 6 of 38
AllenJessup
I believe that's it. If you have that box checked when you save the Layer State. That's the way it will be treated. At least I think so. I don't use viewport overrides much myself.
Allen
Allen Jessup
Message 7 of 38
Joe-Bouza
How do I fix it? I'm not using any vport overrides.
Your Name
Message 8 of 38
AllenJessup
I don't know of any way. I'm afraid you may have to duplicate the settings and save the Layer State again.
Allen
Allen Jessup
Message 9 of 38
Joe-Bouza
Overide removal no problem: Highlight all layers RC remove overides.
However and this is begining to irritate me. I have 2 states "all layers on" & "specific frozen layers" I set and save but when pick from the layer panel it reverts to "unsaved layer state". this shouldn't be so hard. How do you save yours?
Your Name
Message 10 of 38
AllenJessup
I can't ever remember having a problem like that. This is how I have them set to save:
Allen
Allen Jessup
Message 11 of 38
Joe-Bouza
this shows what I am going through
<iframe width="640" height="400" src="https://chronicle.autodesk.com/Embed/d408b46b-5b6e-42dd-a453-1a022b2e429b" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Your Name
Message 12 of 38
AllenJessup
The only thing I see that's different in the way I do it is that I still use the Layers toolbar - not the ribbon. Try typing Layerstate and doing everything from the dialog box. I know that sometimes things work a bit different from the ribbon.
Allen
Allen Jessup
Message 13 of 38
Joe-Bouza
I think the problem may be with "relative" XREF paths
Your Name
Message 14 of 38
Joe-Bouza
Not the path.
MS PS
if in layout tab no worky
if in model tab yes worky
Your Name
Message 15 of 38
troma
In paperspace, or in the modelspace of a viewport?
Mark Green
Working on Civil 3D in Canada
Message 16 of 38
AllenJessup
Joe,
This might not have anything to do with it. But there are 2 kinds of Layer States based on which space they were saved from. If a Layer state was saved from ModelSpace or from an active layout viewport (IOW clicked into MS through the viewport) it's a Modelspace layout. If the Layer State is saved while in a Layout view (PaperSpace) then it's al Layout Layer State.
Could it be that you accidentally saved a Layout as a Model or that you're trying to restore a Model in PaperSpace?
Allen
Allen Jessup
Message 17 of 38
troma
We do all ours in modelspace in a viewport, and they are still saved as "Layout" in the Manager.
Mark Green
Message 18 of 38
AllenJessup
in reply to: troma
We also mostly use modelspace Layer States. The drawing I picked was a complicated one that grew instead of being planned. So I ended up with some layout as well as model. But sometimes I've seen ones that were supposed to be Model saved as Layout cause some confusion. I've done it myself. So I thought I'd mention it. Sometimes you can't see the forest for the trees.
Allen
Allen Jessup
Message 19 of 38
Joe-Bouza
in reply to: troma
In the Model Tab
Your Name
Message 20 of 38
Joe-Bouza
Ok. if I were in a layout tab, opened the layer dialog and selected my newly created filters (most excellent) and froze and thawed the way I want ( that first column being global no vp overrides) why would it save as model? weird.
So now I go to model tab and re-do it. Now I know I saves Model space. Now I have to know and tell everyone to swithch to MS to set the layer state? Something doesn't smesll right here.
Your Name
Rail Community
