Hi all,
i have my layer line type set to solid but all lines i draw are coming out phantom. I have to go back and change each one in the properties. how is this possible?
civil 3D 2013
Solved by Jay_B. Go to Solution.
Most likely your linetype setting got switched from "bylayer" to Phantom.
Enter LINETYPE @ command Line > Select "Bylayer" > Current> OK.
You possibly have current linetype set to phantom. It will override the "bylayer" linetype.
Bill
Type LINETYPE and look at the dialog that comes up.
Possibly says "Current Linetype PHANTOM"
Change it to BYLAYER
