I am using 2013 C3D with SP1. After I publish sheets using the sheet set manager my layer filters stop working (will not filter layers, it will just display the last layer filter used prior to running the sheet set manager). Any help on this is appreciated.
Do Layer Filters work if you set LAYERDLGMODE to 0?
That appears to work if I change the setting on "Layerdlgmode" to 0. Problem now is that's not the way I want to run my layer properties manager window. I prefer to have it docked and using auto-hide.
Thanks for the reply.
A known bug AFAIK.
Discussed here also:
http://forums.autodesk.com/t5/AutoCAD-2013/Layer-Filters-in-AutoCAD-2013/td-p/3562192
