Genious Bill.
Thanks! Should be a good work-around, but will be take some time to set up
each time with parcels, alignments, corridors, etc... Too bad it doesn't
work like it should.
Thanks again!
Tyler Townes, P.E.
"wfb" wrote in message news:42014d2d_3@newsprd01...
> Tyler:
> Here is what I did that seems to work. I was wanting to get my curve tags
> to turn off & on. You can wade through the setup one time and I placed
> the
> tag on layer "tag" (real hi-tech) with my standard color. Now I can turn
> these little rascals off and on conventionally after I either make a line
> or
> place some conventional text in an out of the way area on each defined new
> layer. Click on them in the usual way. Hope this makes sense.
> Bill
> "Tyler" wrote in message
> news:42014946$1_1@newsprd01...
>> I wish layer controls worked better with the new objects and object
> labels.
>> (i.e. layiso, layoff, matchprop, make objects layer current...). A
> majority
>> of the time I control layers' on/off status in CAD drawing space (rather
>> than layer manager). This functionality seems to be lost with the new
>> C3d
>> objects. Try turning a parcel area label off with layoff, the boundary
>> turns off, and the label actually stays on? I have found other objects
>> to
>> be just as finicky and unpredictable. This is a huge time issue, to wade
>> through the layer manager to find the correct layer to turn off, when in
> CAD
>> drawing space it is usually a matter of two clicks without having to know
>> the layer name.
>> If there is any way to fix this, let me know.
>> Thanks,
>> Tyler Townes, P.E.
>> c3d2005sp1
