So I set up a layer state called "0 plot" and save it. In this state, the point layer is turned off such that the point marker (yellow circle) shows, but the point label does not (top view in appended JPG), and the layer state (red marking) is labeled "Current layer state: 0 plot".
Then I need to view the point label for a moment, so I turn the point layer on; the label appears.
Here's the weird part: when I want to "restore" the "0 plot" layer state, I select it and click "restore," and LO! The point labels remain on, and I am given a "Current layer state *UNSAVED*".
I would have hoped the layer state would have returned to "0 plot" upon clicking "restore," but no such luck. This happens with all of our attempts to save layer states, which we prefer to be consistent between model space and paperspace viewports as well.
What am I doing wrong in not being able to restore a saved layer state?
Thanks.
If you use VPFreeze or LAYFRZ with VPFreeze set in viewports. Then restoring a Layout layerstate in modelspace will yield inconsistent results. If you want a layerstate to work in both model and paper space. You can't use VPFreeze.
I'm not 100% sure this is your problem. But it looks like it from your screen shots. I notice that 0 Plot is your only Layout layerstate and having Unsaved as the current layerstate after restoring a layout layerstate in modelspace is expected results.
Allen Jessup
Allen Jessup
CAD Manager - Designer
I think they can work together. What you need to do is set up the vport with the vpfreeze command so you see what you need. Once the viwport is set go to the layer manager and sort the layers by the VPFreeze column. Select all the layers that are frozen in the vport and now freeze them globally. Save the layer state and it will work in MS & PS.
John Mayo
Yeah, John. It requires 2 named layerstates. You have to have a modelspace that equals the paperspace. Nice way of creating it though. Another option is not to use VPFreeze. If you use the standard Freeze command the layerstates would restore equally in both spaces. But I don't recommend that.
Allen
Allen Jessup
Thank you, Jay B, for the response. That drawing of yours does show the scenario that I describe. My problem is that (with many more layers) the saved layer state does not seem to be stable, i.e., if some other layer is opened in model space and then closed again, this latter layer suddenly appears when the "restore" function is used, even though said layer was not intended to be visible in the originally intended layer state. I know I'm making some error in "saving" the layer state in model space, thus producing this instability in saved layer states, but I can't seem to isolate this error.
Does this happen with all layers or just those associated with Civil 3D Objects?
Allen
Allen Jessup
