I have some old custom commands I'm updating to hopefully work with Civil 3D 2008 (and future releases). One of the commands uses "laymrg" in the macro to merge some layers. When this was created, laymrg responded with "Select object on layer to merge or [Type-it/Undo]:" The macro I have then entered "t" followed by the layer name. The layer is created earlier in the macro, so I know it's there to be merged.
The current version of "laymrg" responds with "Select object on layer to merge or [Name]:" If I choose Name I get a dialog box to select a layer. Is there anyway to specify the layer at the command line, similar to the older version of "laymrg" ? Or is there another command or method I should be looking at?
Jay
