Does anyone know of a way to launch these programs without opening Civil 3D? It's pretty silly that we have to launch these programs from within C3D. Express, specifically, is pretty much a stand alone software.
have you tried the start button? Go to you Autodesk collection and click. I can do it in 2008
Joe Bouza
In 2011 they are not under the start menu anymore, only under the Analyze tab. I found the EXE files under "C:\Program Files\Autodesk\AutoCAD Civil 3D 2011\HHApps" folder but you can't even launch the programs from those EXE files.
in 2010 & higher they are not separate programs anymore they are features of the software
DarrenP
Right. So that means there is no possible way to launch them outside of CAD? It's pretty clear Autodesk did not consult a user of their software before making that decision.
just submitted mine. true, it is somewhat annoying that i have to fire up civil 3d to be able to get to these programs! i can understand the "connection" between the pipe networks and storm sewers, but why hydrographs and express?
